Charging Isolator question
i have a 2005 525efi. I want to install a battery charging isolator to charge multiple batteries. Where is the charging wire located is it landed on the starter main power lug?
It does go back to the starter, depending on your application and rigging, it may be better to disconnect it at both ends and run a new wire to the isolator from the alternator. I believe it’s an orange wire.
Thanks I will check into running a new wire.
Is this a single engine multiple battery? Or twin engine?
Isolators work, but a Automatic Charge Relay (ACR) does a better job. The ACR automatically connects to charge the battery(s) and disconnects when charging stops or if a battery goes bad (shorted cell or other).
I have 6 or 8 gauge running from my alt. to the isolator charge post. Funny this came up... I'm switching from the diode style to digital soon. My iso has seen better days. Going with the Promariner #23126 1-alt, 3-battery 130amp
Originally Posted by CJSYD
(Post 4612307)
https://www.bluesea.com/resources/1437 https://www.bluesea.com/files/resour...on_chartlg.jpg |
Just the 130amp iso... alt is 70amp. Was told to rate iso over actual alt amperage. Figured 130 would be good in case I up the amperage of the alt if it takes a dump
(Post 4612312)
No worries and thanks for looking out! That link is a great reference by the way... thanks!!!
+1 on the automatic charging relay. I have two of them in my boat. I have five batteries. The ACR's work great. I used blue sea systems units.
Agreed, the Blue Seas ACR is the way to go.
Isolators are old technology. Voltage drop across the diodes |
The prolsocharge #23124 (wrong part in my above post) is actually a digital version with no diodes or voltage drop. Is that the same concept as the ACR? I'm honestly getting confused now and apologies to the OP for turning this into complication. Not my intention...
Originally Posted by Unlimited jd
(Post 4612303)
Blue seas acr will work great for that
| All times are GMT -5. The time now is 09:59 PM. |
