-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   496 mag IAC trouble (https://www.offshoreonly.com/forums/electronics/360566-496-mag-iac-trouble.html)
Bigdon 05-10-2019 03:28 PM
496 mag IAC trouble
Hey all ,
I have an 05 496 mag the IAC went out and engine died will not start.i sent ecm to whipple superchargers and they repaired a driver chip that was burnt up.i installed a new IAC wiring is good.i got the ecm back and I use rinds software and it has a IAC high output fault .I cleared the fault and it comes right back.does anyone have sone advice for me.
It would be greatly appreciated
Diamond Dave 05-10-2019 11:34 PM
You should hit up BUP on here 100%. He’s probably forgot more about that engine than most even know not kidding. He can also repair the ECM/PCM 555’s and all the others. I’ve used him for a lot of things and he helps out with tech support after the fact too which is really nice! Also worth mentioning, I’ve read a lot of stories where owner had boat to multiple shops and countless months and dollars to still not be fixed then taken to or worked with BUP and fixed in a week. HIGHLY recommend!
BUP 05-11-2019 09:57 AM
DD thanks for plug about what I do. The 555's, I get them in all the time because something has failed internally.. Actually there is 3 main failures that can take place as it seems with ECM / PCM 555 s. Anyone of those failures or even all 3 can take place, and of course other issues can always happen. The key or a positive thing is, Im actually the one who works on the ECM s and also crawls around and fixes the engines as well so thats a huge plus.
PA.WOODCHUCK 05-11-2019 12:03 PM
Found out my 2002 496MAG-HO had a open recall when I purchased last fall. Basically states if engine will not shut off or no start the ECM has a internal issue. If it still runs then needs a harness pigtail installed. If it doesn't run needs the pigtail and ECM. I can check, and also BUP can with your engine number.
Bigdon 05-11-2019 02:44 PM
Problem fixed it was a blown fuse ( really a 2 dollar fuse.) thanks for giving time for the advice.the fuse is located in what looks like one of the many harness plugs.
BUP 05-12-2019 09:28 AM
got your PM just now asking for help, super glad you got it fixed because I have to add, its very hard to even help everyone on my end especially for free when I have so many paying customers.
. Want to ask thou --- the money went to whipple as they did not offer any help after the fact ? They did not offer to help you with your issues afterwards just asking ? I did not see anyone from whipple reply to your OSO post either. Did you PM them or email asking for help ?? They are prob busy like I am.
Will add really sorry for the late timeframe on my part seeing your PM for the asking help but I do have an excuse thou, I was helping out my paying customers. Sorry about that one..
