-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   Shore power transformer (https://www.offshoreonly.com/forums/electronics/369547-shore-power-transformer.html)
flat rate 12-06-2020 11:09 AM
what are you trying to operate? It doesnt look like a fuse will do anything, there isnt anything connected to it.
AllDodge 12-06-2020 12:10 PM
Originally Posted by F14A water jet (Post 4768165)
See pictures...does it look like I just need to install fuses? What size (fuses)?
Agree, depends on what your wanting to run
First one on the right is the main fuse to feed the other 3 to the left
F14A water jet 12-06-2020 12:19 PM
I am trying to get the shore power transformer to work as advertised. I would love to see a picture with wires attached as factory. Think I have a god schematic but a labeled picture would be IDEAL.
F14A water jet 12-09-2020 07:15 PM
The cockpit 110V outlet works when shore power is attached. Now I kinda believe the system is installed and working BUT the LED (that tells me how the charging) seems to be burned out...BUT I would like to confirm.
Can someone tell me (with shore power hooked up) where to check for battery charging voltage and what the readings (volts DC) I should be seeing (depending on the selection on the Perko switch).
AllDodge 12-10-2020 05:54 AM
Should see at least 14V on the battery when charger is ON
Helmwurst 12-10-2020 07:33 AM
If you do not have any factory manuals, they are available on line for free. Formula published very detailed drawings and schematics for their boats.
ThisIsLivin 12-10-2020 08:49 AM
You may want to upgrade the battery charging system if you are using AGM batteries. The internal resistance and voltage is slightly different than typical lead acid batteries. I use a Pro-marine dual battery set up that has different modules for different battery types.
Awash 12-11-2020 11:35 AM
Here are a few things that may help
  • In that panel as others have noted you have no circuits connected, the 12V+ positive (red wire) goes to the 12V bus side and there are no wires connected to the the 12v terminals
  • Black wire is the 12V-
  • You would have to determine what you wanted to run, wire it to one of the output terminals and add the correct fuse
  • You are asking about a battery charger typically a charger is 110V and has its own step down transformer to provide about 14V DC as someone else mentioned.
    • Typically a battery charger would not be 12V DC in with 14V DC out..... It is possible electrically to do this but I have never seen anyone use a buck boost transformer in a marine application
  • With all the above being said I would go to the battery charger itself and check for 110V power at the charger (input power) with the 110V breakers turned on
    • To help look at the wiring going into the charger it should be black, white and should have a green wire (ground) this would help to indicate its 110V wiring. You may have to take the cover off the charger
  • No power at the charger trace the wires back to see where they land they should land to one of the 110V breakers
I have assumed basis you posts that you have a multimeter
If you need more help send me a private message and I'll give you my number.
As a final note since your checking everything when all done make sure that the ground bus that has all your green wires landed on it actually has a green wire that goes back to your shore power plug this is critical to the safe wiring of the 110V AC power inside your boat
F14A water jet 12-11-2020 12:32 PM
Thanks...I'll try to follow your advise/suggestions/tests.
Awash 12-11-2020 06:30 PM
You may have sorted this already but here is some more information
Company website that made the unit: https://www.progressivedyn.com/
Picture of another unit like yours but larger : https://www.google.com/search?q=Char...byMOVSgCT7IHxM
Looking at the larger unit you can see the circuit board for the battery charger is located behind the panel as I would bet yours is also. This would mean their is no charger by the batteries and is all located in the unit in your pictures. You can likely get it fixed either yourself or Progressive Dynamic may help but I would not charge anything but plain jane lead acid batteries on it.
Good luck with the project.
