Mercury 500efi no fuel pressure. Help lol
I have a 500efi that’s fed by an Aeromotive pump. I’ve check the pump separate from the efi system and it functions as it should. However when I turn on my ignition the pump doesn’t kick on now. What could cause this? What should I check? Thank you for your help. I’m lost on this and I don’t want to damage the ECU by accidentally shorting something
Could use a motor serial number
Start by checking fuses,there on top the motor Use a voltmeter and see if the Main Power Relay (MPR) energizes when key turns ON |
Originally Posted by AllDodge
(Post 4784948)
OK, let us know what you find
Solved
It won’t let me post pics since I’m new, but it was definitely the fuses. The corrosion had destroyed them and the female pins in the dongle. It’s running great now. Thanks for all the advice
| All times are GMT -5. The time now is 01:21 PM. |
