94020 Adapter Wiring Schematic
Hello everyone,
I, like many, have had a hard time locating a 94020 adapter to scan for hours on my TB-V. I saw someone on here mention they were able to get the wiring schematic from Rinda but they never shared it with group (or maybe I didn't look hard enough) and I HATE when someone solves something without SHARING. So I created an account just to share what I found because I know it will help someone somewhere. I attached the schematic to my profile album since I can't post here. I know for sure that the wiring will work for a Gen 2 and 3 ICM with a MerCruiser / TechMate Scan Tool, I'm not sure about Diacom (someone chime in). Gen 2 will require only the Yellow and Violet Leads (no need for the 4 pin connector). Gen 3 does not need the Yellow and Violet Leads as its being used in the 4 pin connector. |
no link in your post
It's on my profile album. I can't attach until I get to 10 posts
Originally Posted by sutphen 30
(Post 4805261)
Can you send me the schematic
Here are the pics from his profile album
https://cimg8.ibsrv.net/gimg/www.off...a2665346a4.jpg https://cimg1.ibsrv.net/gimg/www.off...f34a366bcc.jpg |
Originally Posted by minteeeze
(Post 4805375)
Thanks Griff..
Also, if I remember correctly, you need to attach the black aligator (negative) clip to your block and the red aligator (positive) clip to your battery. It won't work if you attach both to battery. Another thing, the 4 pin connector is off a suzuki gsxr hayabusa starter relay.. Just google "hayabusa starter connector" and you'll see it on amazon and ebay for about $9. You'll only use 3 of the 4 pins The 6pin din was the hard part to find. Search the numbers below on amazon and it should pull up what you need. B00K855H1E B0978QX3Q8 |
I got banned doing that before
(Post 4861279)
| All times are GMT -5. The time now is 10:50 AM. |
