-   Electronics (https://www.offshoreonly.com/forums/electronics-291/)
-   -   BBC spark plug wire set (https://www.offshoreonly.com/forums/electronics/377665-bbc-spark-plug-wire-set.html)
scippy 11-10-2022 10:38 PM
Time to purchase 2 good sets ~ for my BBC with AS&M EFI's ........any good recommends?....Thanks, Scippy
CheckmateScarab 11-11-2022 09:23 AM
I have had great luck with JDMSpeed 10.5mm spark plug wire set for BBC (I cant post links, too new lol)
I was skeptical on the price but worked great on a 454, currently rebuilding it into a 496 and will be reusing them. The one issue I ran into was if you want to use cable combs / clips, its difficult to find ones that support 10.5mm. I ended up using 'Taylor Clamp-Style Wire Separators 42709' from summit racing and they do the job just fine
ThisIsLivin 11-11-2022 09:25 AM
I bought a set of Taylor custom 8.5mm wires as they were recommended by Daytona Sensors. Very low resistance and kit came very complete. I have a crimp tool and my layout is anything but stock so I always get the custom kits. Plus my coil is mounted further from the distributor than stock so I have to make my own. I will buy them again if and when I need new. Best part is they aren't expensive.
DrFeelgood 11-11-2022 09:30 AM
I got the "FAST" Firewire set based on a recommendation here. Nice wires, good price
scippy 11-11-2022 04:23 PM
Thanks all!....a set of wires with low ohms and very low resistance is what I'm after for my EFI engines...wil research all above. thanks much!
Gimme Fuel 11-14-2022 08:35 AM
FST-255-2416 is the part number. Running them both on my 502MPI's, fit very nicely and about the best specs for the money.
Diamond Dave 11-14-2022 09:53 AM
I got mine here John works directly with Moroso for custom fit marine app ones 40 ohm per foot best you will find.
Boats Unlimited | Marine Technician Service | Inspections (boatunlimited.com)
scippy 11-14-2022 11:17 PM
Just picked up 2 sets FAST 255-2416.......they state 25 ohms per 12"....that's just about the lowest I've seen....thanks all!
bigboat28 11-16-2022 08:34 AM
Do these sets fit around headers?
DrFeelgood 11-16-2022 09:03 AM
Yes, they fit under my CMIs without a problem.
