Need a 12v source for my electric choke...help
Hi guys, so I just swapped out my broken Fitech EFI for an edelbrock 1410 carb. This on my gen v 7.4l mercruiser. The problem I have is the previous owner removed everything to do with the original Quadrajet . Now I need a safe and reliable 12v source with key on to run my electric choke. According to Edelbrock the alternator is a No, the coil is a No... I can't figure where to get my key on 12v from? The starter solenoid? Could I direct run it from the battery with a manual toggle switch? Need some guidance so I can remove this dead boat from the dock before October. Thank you in advance
The purple wire is what feeds the choke. It might also be on the coil , or an electric fuel pump relay.
https://www.mercruiser-shop.at/data/..._0000029_1.pdf |
Just make sure it's not your tach wire. Don't ask me how I know that. Lol
Why do you need a choke on a Holley? Pump it 2x, 2 clicks on the throttle and hit the key. That is all I have to do.
Purple wire is marginal at best for powering even just your ignition coil, let alone other things. It is small gauge wire and comes from a million miles away . Ie: ignition switch.
i’d install a relay to use the purple as just a trigger. Then you can wire the coil and choke with appropriate sized wire from a closer battery source ie: in engine comp’t. here is a generic internet pic of how to wire a bosch 4 pin style relay . In this example he was powering lights. You’d be powering choke and/or ignition coil. https://cimg0.ibsrv.net/gimg/www.off...b36d040a1.jpeg |
| All times are GMT -5. The time now is 10:18 PM. |
