-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   Daytona 25 with Ilmor 625 (https://www.offshoreonly.com/forums/eliminator/114839-daytona-25-ilmor-625-a.html)
MyPetViper 10-21-2005 06:42 AM
I have the opportunity to pick up a 25 ICC open bow and rig it with a V10 625 for a very attractive price. For full hydraulic steering I would use my Bravo Shop ( BMax) Transom Assembly. I also have a Bravo X drive with Max Machine Works top cap, and IMCO 2" lower with Max Machine Works internals.
The BMax Transom Assembly adds about 150 lbs, but the Ilmor (all aluminum) is about 200 lbs lighter than a Merc 525.
Is there room enough for this set up in a 25 Daytona? Will the weight shift be a problem in fore and aft center of gravity?
Is this too much hp for this boat? It has the largest beam that I can fit in my lift. For use on a larger inland lake.
Thank you for your comments.
Airpacker 10-21-2005 07:29 AM
Re: Daytona 25 with Ilmor 625
No where near TOO MUCH power. Theres lots of 25's out there with huge power in them. Teague ran one with 1350 hp in it to 144mph a few years back. I think it would be a real sweet package.
Cat man do 10-22-2005 11:16 AM
REAR SEAT HAS TO BE MOVED FORWARD, IT WILL BE TIGHT, MANY 25s WITH #3,4 AND 6s, WITH NO BALANCE OR CG PROBLOMS.
TimeToBurn 10-24-2005 03:25 PM
YA! I talked to BOB T. in person about this event. He said, that the two passes he made with that boat was the best rush he has ever experienced!
:D Airpacker... you made my day bring this up. Good job.
PowerboatsNW 10-25-2005 02:48 PM
we have a 26 and 27 daytona's with the vipers and they run very well! If you would like a deal on one pm me. We have done a few and if you just need some advice we can help with that too.
Steet 11-03-2005 07:15 PM
You can not go wrong with the Ilmor package. I have 2 of the 625's in my 41 Velocity and it is the best engine I have run to date after about 30 years of powerboating. I am a Chevy Man, but I have to admit, that the Ilmors are the total package in a boat.
