New 27 Daytona twin step pick up mounting
Where is the best place to mount a thru hull adjustable pickup for an intercooler?Thanks for any help.
Re: New 27 Daytona twin step pick up mounting
NO! Good place , get a dual output water pump, there is a link from offshore only, do a search.
The well in one of the outside sponsons near the drain plug. Anywhere in that area will be in the water at all times. That's for a thru-hull fixed pick-up, you could run that for the chiller OR the motor and use the drive for the chiller. Either way would work.
| All times are GMT -5. The time now is 12:05 PM. |
