-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   27 Daytona owners (https://www.offshoreonly.com/forums/eliminator/155007-27-daytona-owners.html)
GT 04-02-2007 08:35 AM
27 Daytona owners
Hey guys,
I thought I would check with a few of you and see what kind of speed and drive set-ups you have. The reason is: I have an Out of State customer with an 05 27 Daytona/Whipple 525. The boat was set up originally with a 2" short sportmaster and the engine was installed 1" high from the factory:( .
As soon is this boat starts to run over 85 mph, the prop starts to gradually blow out. It also blows out bad going on plane. At top speed with a 30 lab, the slip is over 13%!
I would love to hear about some factual set-ups from you guys, so my customer does not waste his money on drives, spacers, props, etc............................I think all of you will agree,,,,,,,,,,,,,,,first thing: The drive needs to come down!
gsmith9898 04-02-2007 09:13 AM
Sell me the whipple and all things should correct themselves.:evilb:
PWRCAT 04-02-2007 09:33 AM
why the 1" higher motor mounts? Id think its up enough with the shortie.
B BOATER 04-02-2007 11:59 PM
1 inch shorty Imco Extreme, 1.25 gear 30 pich prop turning 6400rpm, 10% slip with the prop we are running currently. You can figure speed, would rather not say for insurance purposes. The faster you run the more the slip seems to increase. 7 %seems to be a good number for these hulls thats were they should be when everything is right although I have seen better.
I could not run a 2'' shorty on my boat because it was to high. We are currenty going to try adding a 1'' spacer to see if it helps our slip%.
gsmith9898 I have quadrotor for sale if you interested Cheap!
GT 04-03-2007 08:13 AM
Thanks,
Yah, It's pretty bizarre that the boat was built with the X dimension 1" high to begin with, and then the 2" shorty was added. I would really like to see how it runs when the drive is down a little deeper. The lab props seem to be working ok for you guys?
throttleup 04-03-2007 08:56 AM
What is the make of the prop your running? If it is a Bravo I remember to use 29P not 30P. Also with your drive that high you are really set up for a 5B propeller rather than a 4B. You should try a 5B and post your data.
Julie
gsmith9898 04-03-2007 09:02 AM
Julie
why 29 and not 30?
GT 04-03-2007 11:23 AM
That is what I was thinking,,,,,,,,,,,,,a p5 or a p5x. I will let you guys know what he tries. Thanks
Cat man do 04-03-2007 04:33 PM
Gary, Hi Is That Bruces Boat? Marty
gsmith9898 04-03-2007 08:34 PM
Marty, did you get the pm I sent you looking for the place you stayed last year at loto? Gary Smith
