-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   winterizing with Thru hull pickups (https://www.offshoreonly.com/forums/eliminator/172483-winterizing-thru-hull-pickups.html)
QWKRN U 11-02-2007 10:53 PM
For those of you with 496mag ho's and Thru hull pickups are you adding any antifreeze to the raw water side of the system and if so how? or do you just pump up the air drains and remove the blue plugs?
