-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   28 dayotna (https://www.offshoreonly.com/forums/eliminator/185865-28-dayotna.html)
DALLAS 05-02-2008 05:47 PM
28 dayotna
what are you guys running for props. i have twin 525 with speedmaster drives. i am currently running 36 lab merc bravo props good top end if i ever get there. low end and mid range is not good.
MikaylaHunterCig 05-04-2008 12:02 AM
Give Herings a try
you would be amazed at the improvement these props will offer over bravos
Not enough bravo owners give hering a chance thinking there too expensive - however anyone here would happily spend 3-4k now if you could add 4 + mph w/o any other mod's
A set of herings do this for your 525-28
grads2112 05-05-2008 09:47 AM
I have the same set up as you and I run 32p 5 blade maximus props and am very happy with them. I have very little if any blow out when getting on plane, great mid range and a top speed of 111 with them. I've been faster with other props but these work the best for how I boat. What kind of speeds are you seeing with the 36 4 blades?
DALLAS 05-07-2008 03:21 PM
28 Daytona
I Have Run 115 With 4 Guys But It Takes Forever To Get There. I Want My Kids To Ski This Year And Theses Props Arent Going To Cut It. Plus My Mid Range Is Very Bad. I Was Just Going To Go Down To 34 Pitch Bravos, But I Wasnt Sure
jdnca1 05-07-2008 10:07 PM
Dallas...try the Hydromotive P5X or talk with Brett at BBlades...he can get you into say a 32 bravo and pitch it to a ~35 with cup...that way you get the planing and acceleration of the lower pitch with almost the same on top.
tblrklakemo 05-10-2008 12:59 PM
just get these motors and you can spin whatever prop you wish....
http://www.offshoreonlyclassifieds.c...o22319-en.html
Crazy little boat. :evilb:
jdnca1 05-11-2008 06:34 PM
That boat has stupid power...probably runs ~160 if someone had the balls...
blownboat 06-13-2008 12:02 AM
What ratio are those drives?
DALLAS 06-16-2008 03:50 PM
Drives
1.5
CheckedOut 06-16-2008 03:51 PM
Originally Posted by MikaylaHunterCig (Post 2547017)
Give Herings a try
Hey Dave,
What ratio are your drives, and what pitch props are you running?
