Best Wax
What wax do you guys use on our Elims? It's about that time to get things shining......
try this..not known as much out west..mostly southern states. Easy on and easier off. Lasts, and the best thing about it is..it has the deepest shine of anything that's out there. Call me if you have any questions. Thanks Jeff
www.leveragepolish.com if you do a search on here there are multiple threads.. this is where you can buy it http://www.topnotchperformancemarine...oducts-c2.html |
Thanks Jassman. I will check that out.
Before you posted I was at fisheries supply yesterday (local wholesaler) and picked up some 3M scotchguard wax (09062). I have been impressed with most 3m products so i am going to give this a shot. http://solutions.3m.com/wps/portal/3...ations/Marine/ I also grabbed some 09009 as well for the areas which may need some light polishing: http://solutions.3m.com/wps/portal/3...glGSJS11T0NCbl I will try to throw up a couple pics after it's done.... |
I switched from Meguires to Hammerhead Wax Frenzy. Love the stuff.
Jeff |
| All times are GMT -5. The time now is 08:24 AM. |
