30' Cat owners
Charter Member#157
30' Cat owners
I need some info on the center tab setup I have seen on these.
I have seen several that have a keikafer tab mounted on the transom above the notch
I would like both the part numbers of the mounting plate and the tab.
Ithink it is a 280, but not sure.
Any help would be greatly appr.
This Cat is trying to keep up with the Big Dogs
MnFastBoat, I'm sure there are other 30' owners out there. They just don't check this section as often as the main ones. I would help but, I don't know the answer. Sorry. You might want to try the Technical Q & A area.
