23 Daytona ?
I have a 88 23 Daytona with the standard offset brackets. The boat has a pair of OMC 20" mids that are mounted as high up as I could get them. My question is can I run a pair of Merc 15" mids if bolted all the way to the lowest position.
Thanks, James |
need help with my question time to decide to rebuild motors or go with 15"
Stay with 20". 15's will go under water when comming off plane. Put on a set of hydrolic jack plates so you can raise to where you need when running.
Originally Posted by perfmarine1
(Post 3475706)
| All times are GMT -5. The time now is 03:03 PM. |
