-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   1998 Daytona - What Is Factory Finish? (https://www.offshoreonly.com/forums/eliminator/248147-1998-daytona-what-factory-finish.html)
low buck 02-22-2011 09:53 PM
Greetings:
I have a 1998 27' fundeck that has just developed some slight blisters on the sides of the boat, towards the rear, just below the water line. The bottom seems fine.
I am researching to find the best fix and materials. Could anyone tell me what the FACTORY FINISH on this boat would be? My unqualified guess is gelcoat -vs- base coat / clear coat. I'd like to know if it is gel, did eliminator use a vinyl ester based gel or poly? Again, I'd like to repair with the best possible compatable materials.
You response is both requested and appreciated.:coolcowboy:
Ptufaro 02-23-2011 07:55 AM
If it is factory it is most likely gelcoat (a pic may help). I have found that calling the factory is the best place to find out what material and brand they use. The people there have always been helpful when I call.
