You might check out the drive heigth on this one to compare. http://cgi.ebay.com/ebaymotors/07-EL...rQ5fMotorboats
Talk to the previous owner and Eliminator before you start making changes. It might be possible you are not using enough up trim. Let it pack air. Make sure you are driving it correctly before spending money.
Originally Posted by GPM
(Post 3461022)
I was told later that Eliminator set up a bunch of them for the Blackhawks but they were failing so they just put Bravo's on. I was told they all had the porpoise problem.
Michael |
22 hopps
I had a 22 that was out of control over 80....Brent at eliminator told me the fix...tunnel extentions with a couple degrees down angle. This is common to many 22s and getts worse with more power. I could not drive it once I put a blower motor in......ON RAILS after the extentions. PM me your number and i will get you the details. They are a simple build from aluminum plate and flatbottom style hardware.
| All times are GMT -5. The time now is 04:07 PM. |
