removing Whipple off 525, 27 Daytona
Have a 2003 27 Daytona I would like to bring back to stock.
Currenty has a blue whipple installed by Paul Pfaff with 91 hours. Stresses me out to much. I'm always worried about my XR drive blowing and costing me a ton to fix. I'm seeing right over 100mph with a 32 pitch four blade. Looking to trade with someone that has a stock 525 with low hours. Thanks! |
What is everyones thoughts on this setup? I'm I crazy to touch a perfectly running 100mph+ boat?
Or do you see my point? |
Just dont run it hard if your that worried. I dont think you'll like going from 100 to 80s. Also you will have to prop down.
Originally Posted by riverrat
(Post 3849179)
enjoy the power and have a spare drive in the pick-up
jeff a. |
Originally Posted by CumberlandDayton
(Post 3849139)
Or do you see my point? If your easy on the throttle starting out and up through the mid range you will be okay. Change lower unit oil often. I have 140 hours on my 600 sci with a whipple stage 2 kit in it with no problems . |
I really like running poker runs.
Hard to be easy on a boat running in the waves and other fast boats. |
Also,
Isn't coming on plane one of the big issues? Even with being easy on the throttle. It builds so much TQ @ 3,000rpms which is what it takes to get my boat on plane. |
Put a 30 prop on it. Its much easier on the drive and the acceleration is way more fun. You will only loose about 7 MPH. Just stay off the rev limiter.
Acceleration is fun, but isn't that one of the no-nos with the Whipple? Hard on the engine and drive both?
How do you feel about the rise in rpms from the lower pitch prop? With the 32 I can cruise at a lower rpm, which puts less stress on the engine, right? |
| All times are GMT -5. The time now is 09:18 AM. |
