-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   27 Eliminator on boat lift (https://www.offshoreonly.com/forums/eliminator/296427-27-eliminator-boat-lift.html)
bouncedcheque 05-15-2013 02:43 PM
Any reason why you shouldn't position the bunks on a boat lift such that they are under the sponsons rather than in the hull indent that's between the sponson and the centre pod (like where the trailer bunks go)?. Reason I ask is the bunks on the lift are not "tall" enough and can't reach up to carry the boat in the intent. Thanks.
Randy Nielsen 05-15-2013 04:43 PM
I would guess you can set it up that way but it would be a bear to center it up as compared to sliding over the rails. Same with the trailer. JMO Randy
CumberlandDayton 05-15-2013 08:55 PM
Super easy fix. Get 4 new raises to increase the height.
I had the same issue, had a tech from HydroHoist walk me through converting a vee lift to a cat.
