-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   Thru hull water depth transducer location on 25 Eagle? (https://www.offshoreonly.com/forums/eliminator/300185-thru-hull-water-depth-transducer-location-25-eagle.html)
cloudmaster_321 07-22-2013 10:13 PM
I did a little investigating tonight as to why my depth gage has been intermittent lately. Turns out the thru hull transducer came out of the epoxy. It's been in there for 3 or so years, must not have stuck that well. Anyways, i know that my depth gage would really never read anything above a slow no wake speed with my hull. Is there a magic spot that can get this better? I had it located centered basically right under the engine prior. If there is a better spot that may let it read at higher speeds than just idle please let me know. Thanks.
