23 daytona
Just picked up got a 330 454 w trs. How fast will it go what prop works good with it i need more power for sure any help ???
Come on guys a guess???
Pics or it didn't happen. :lolhit: I would guess around 70ish?
Hope its better than that the activators w 500 Hp r going 90 that's a v bottom
Originally Posted by tripps
(Post 4487457)
I know its a suburban or cabincruiser mota. I built a 598 that made 680 on pump gas w a 1050 but I'm just gonna build a 500 so I don't wreck drive or tranny
I've got one. Mines and 85 with a "trs" also. With 330 hp it'll probably run about 60 to 65. The only issue with the trs on these boats is that they set them up with a very deep prop shaft depth which is why I built a custom lower for mine raise the prop shaft up to right at 4 inches below the boat. I've got 670 hp in mine and I've been 96 in it so far with two people and 70 gallons of fuel. Still haven't aired it out completely yet.
Yeah the drive is real deep what prop u using? How did u modify lower thanks
I'm running a 4 blade 30 to 31 pitch bravo props right now. If you go to the "drives and lower units" forum you will find my thread on trs up with bravo lower
I checked it out page 7 nice job how did u locate the drive shafts ???
| All times are GMT -5. The time now is 05:33 AM. |
