-   Eliminator (https://www.offshoreonly.com/forums/eliminator-35/)
-   -   25 daytona Max speed (https://www.offshoreonly.com/forums/eliminator/373569-25-daytona-max-speed.html)
fbc25el 08-22-2023 10:09 AM
Originally Posted by Scotty17509 (Post 4808011)
I recently bought a 1999 25 daytona. It has a 540 with brodix heads, little over 8 to 1 compression with a BDS 8-71. The timing is set at 25, and boost peaks at about 6lbs. It has an older bmax drive, that is 1.30 ratio with their standard length lower. Prop is a 28 Bravo 1 that was slightly worked on, and has a 29 stamped on it.
It pulls about 52 or 5300 rpm and best I have seen with it is 88 on GPS.
I see people on here claiming to be running near or over 100 MPH with Less Hp than my setup. (I'm guestimating i should be around 750-800hp)
Do I have something setup wrong?
I would try a 26 prop. I think you would want to spin the motor a little more rpm.
Scotty17509 08-24-2023 02:50 AM
thanks for the input! I don't have all the engine specs, but i do know it has a hydraulic roller lifters/cam. It has a chip in the msd limited at 5800. I'd think I few hundred more rpm would still be OK and probably more into the power curve.
I'd like to try some different props, maybe a little less pitch to get more rpm. Not sure which to go with. I have access to try a 27p cutting edge. Thinking I may give that a try this weekend. From 29p to 27 may be too much rpm, but I'm interested in what it will do.
boostbros 08-24-2023 06:43 AM
the 26p bravo likes rpm we turn our 540 6500 and more in a 25 foot active thunder yet gets on plane with 6 people in it
Alexgonzo18 10-21-2023 11:39 PM
Did you ever figure out your prop to hull dimension or bump timing up?
