30' Cat owners
I need some info on the center tab setup I have seen on these.
I have seen several that have a keikafer tab mounted on the transom above the notch I would like both the part numbers of the mounting plate and the tab. Ithink it is a 280, but not sure. Any help would be greatly appr. |
common, there is no way there are no 30' Daytona owners here???
anyone? |
MnFastBoat, I'm sure there are other 30' owners out there. They just don't check this section as often as the main ones. I would help but, I don't know the answer. Sorry. You might want to try the Technical Q & A area.
| All times are GMT -5. The time now is 08:09 PM. |
