thru hull pickups
how many eliminators have thru hull pickups and where are they located
i am going to install some on my 33 daytona and was just wondering where to start |
Re: thru hull pickups
You should place the low water pick up on both the outside sponsons, specifically between the two stringers inside each sponson. (Inside every Daytona… there is a small stringer and a big stringer (the motor mounts is bolted to the big stringer.) This way the pick up doesn’t produce air in front of the drive/prop. The pick up should drop 8 to 12 inches.
I recommend you call Eliminator for more advice. Good luck. |
most of the pickups that i have looked at only stick down about 1/2 inch or so
Let me clarify... I wanted to say 8 to 12 inches forward from the transom.
| All times are GMT -5. The time now is 05:40 PM. |
