-   Excalibur (https://www.offshoreonly.com/forums/excalibur-125/)
-   -   Anybody got a 27 with a bravo? (https://www.offshoreonly.com/forums/excalibur/123953-anybody-got-27-bravo.html)
jdub 03-04-2006 05:54 AM
Looking for some dimensions on a 27 notched transom with a bravo? I would like to know what the distance is between the bottom of the notched transom and the bottom of the gimbal?
MDGperformance 03-04-2006 09:07 AM
Re: Anybody got a 27 with a bravo?
Not sure of that dimension but we set one up with the x dimension at 17.5 and worked great , going up any higher you might have to use 5 blade to get any gain, if you mount drive higher you can always add spacers and experiment with different combos. It all depends on how much time and money you want to spend to maybe find a couple of mph.We ended up with ours at about 17.5 running bravo 1 4blade.With the spacers removed the boat ran worse, but 5 and 6 blade props were not available back then.
