-   Excalibur (https://www.offshoreonly.com/forums/excalibur-125/)
-   -   Cracked stringers (https://www.offshoreonly.com/forums/excalibur/205589-cracked-stringers.html)
manaze 03-25-2009 10:18 PM
Cracked stringers
Help!! I just picked up 1981 27' excalibur! I have several issues that i need to address right away. Number one concern is that the engine mounting plates that sandwich the stringers look to be aluminum and have corroded to the point that the expansion of the plates have begun to crunch the stringers on both sides and resulted in bulging upward and cracks in both stringers. What material are the plates, what would corrode, and what is a good fix? thanks so much, Mike
DareDevil 03-26-2009 12:01 AM
They are aluminum !!! if there corroded u need to replace, engine out ,unbolt and rebuilt stringers ,since my quess is the core in them is rotten otherwise they should not get damaged from the plates !!
I know thats not what u whanted to hear ,but now is the time to do it right !! SORRY:eek:
manaze 03-26-2009 09:42 AM
Thanks DareDevil, I appreciate your time. I am not sure what the construction of the stringers are. I assumed sometype of 2X wood. I was planning on just unbolting engine mount plates one side at a time and glassing over stringer, gelcoat and replace with like stainless steel plates..? Sufficient? or much more involved? any input appreciated...MIke
Westcoast 03-26-2009 10:02 AM
That is just a band-aid. Stringers are wood and if they are wet they are most likely rotten.
spazboz 03-26-2009 10:27 AM
I agree with these guys, the only right way to fix this is to just get it out of there and replace it. And be prepared for the worst, many times things will be worse than it looks from the surface in these matters.
Good Luck, Nick.
manaze 03-26-2009 10:53 PM
Next Step
thanks all for your input. I will wait for the snow to let up here in SLC Utah and then take a few shots in the sunlight and repost to this forum for further consideration. thanks again...my first post...
ps..what a stunning boat...i am taking the plunge....Mike :)
myscarab30 03-29-2009 11:29 AM
Any pics of the boat ?
manaze 03-31-2009 11:02 PM
pics
folks, is there an easy way to post pics of boat/stringers
thanks, Mike
myscarab30 04-10-2009 05:12 PM
[QUOTE=manaze;2833637]folks, is there an easy way to post pics of boat/stringers
thanks, Mike[/QUO
You have to be a payed member
Jammin' 04-16-2009 06:07 PM
There's an old 27' Excalibur sitting and rotting in the yard at the shop where my boat is. I can't get over they way I love the shape of it and the 31'. To my eyes, they are just right.
