-   Excalibur (https://www.offshoreonly.com/forums/excalibur-125/)
-   -   New Excalibur project !! (https://www.offshoreonly.com/forums/excalibur/226748-new-excalibur-project.html)
machloosy 12-20-2012 09:22 AM
Very cool to see real progress on this old girl. Keep it up?
JETTDOGG 12-20-2012 12:31 PM
Coming along nicely.....did you use the same upper bolt holes from the trs for the bravo.....or does it just look that way?
Boatally Insane 12-21-2012 07:12 AM
I filled everything in then re-cut / drilled everything but I think it did come out pretty close to where they were..
Doug
Philo312 01-26-2013 12:55 PM
Beautiful! Nice job! I do know those hulls were build extremely strong (and thick!) I'm curious if you had to re-glass or reinforce the stringers or replace any of the old wood.
Boatally Insane 01-30-2013 09:33 AM
Nope ! Everything looks good so far... No rot at all !
The stringers are only 6" so I'm fabricating some engine mounts that will spread the load over a foot on each side to hopefully prevent any issues.. :)
Doug
sparky24 01-31-2013 08:53 PM
there only 6 inchs tall? mine has at least 12 inches thats odd
concept509 03-28-2013 11:29 AM
What kinda of primer did you use just regular automotive primer? An clear will stand up?
Boatally Insane 04-25-2013 09:27 PM
I used the Nason 2K Urethane Primer which I see now has been discontinued..
The paint is Nason Ful-Thane®2K urethane single stage paint.
Hopefully it'll hold up. :whistle:
Doug
RBT 04-26-2013 09:07 AM
Cool project, I had a 1979 that I restored a long time ago. Had a trs with merc trans, bought a new 454 mag from merc added a b&m 174 blower gill exhaust v6 timing module, gaffrig gauges full Latham steering. Etc.
I suspect it was about 450 hp, and would run 75-78 on the liquid filled gaffrig speedo. Should have never sold it.
sparky24 04-26-2013 11:56 AM
Is that a typo 450 up I would think that set up would be 550-600. How did the blower fit with the merctrans out back i am restoring mine right now have almost the exact same setup but I didn't hunk I could fit a blower
