-   Excalibur (https://www.offshoreonly.com/forums/excalibur-125/)
-   -   24' who's got one (https://www.offshoreonly.com/forums/excalibur/51677-24-whos-got-one.html)
thedonz 09-23-2007 08:51 PM
3 Attachment(s)
very nice 79Ex.....
I am resoring a '79 Monza 24'....same hull....going with a 540 and Bravo 3.......(replacing 383/Pre-Alpha combo).......
Hang Time 27 09-23-2007 10:09 PM
Originally Posted by thedonz (Post 2281879)
very nice 79Ex.....
Bravo three, as in counter-rotating props? -- How tall is that drive compared to a bravo - as in how much higher of an x demension will you need, or is it the same? I figured they were taller to allow for larger diameter props because they are meant for heavy cruiser types - I would think it might be hard/expensive to dial in the right prop sizes because no one is using the pitch you are going to need -- because in most applications that drive doesn't usually see anything over 50-65 mph.....
thedonz 10-04-2007 12:00 AM
I'll need to go a bit higher on the x, if doesn't work out, I'll go with a B1 lower and a spacer.......just got a great deal on the B3 so couldn't pass it up
Hang Time 27 10-04-2007 09:29 AM
Figured that was reason - the Bravo I put on my 24 came from a burned up boat with only two seasons on it - $1,500, but I had to take whole boat carcus - landfill here takes em if under 20' - I just cut 4 ft of bow off - sold $500 in engine parts, so nice drive and transom assembly was only 1k! Found that deal by chance - sure would like to know how to find those deals on purpose...................
