Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Rust on Gel Coat ....... >
Old 04-25-2005, 10:45 AM
offthefront's Avatar
Default Rust on Gel Coat .......
Somehow I got metal shavings on the deck and the swim platform ...what can I use to remove the stains ?
offthefront is offline
Old 04-25-2005, 07:19 PM
cuda's Avatar
Default Re: Rust on Gel Coat .......
Mike, you caused me to have to get up go out to my garage to look for the name of the stuff. I didn't find it, but I did remember the name while I was looking. It's called FSR (fiberglas stain remover). It's a blue gel you let sit, then wipe it off. It takes off most stains. I've had to sand some off before. I think it depends on how long you let the rust sit. You can get it at any marine supply store.
cuda is offline
Old 04-25-2005, 07:44 PM
Ted G's Avatar
You could also try CLR just be careful how long you leave it and don't get it on skin.
www.cbpba.com
Ted G is offline
Old 04-25-2005, 08:50 PM
thanks guys .. give em a try .....the worst now is on the swim platform ..on the non skid part ...
Old 04-25-2005, 09:13 PM
Alumabrite. This is a basic (not acidic) solution that will dissolve rust stains before your eyes.
Caution: Do not put on aluminum or stainless. This stuff was made to "etch" metals before priming. It will discolor your raw metals.
Available at all marine hardware stores.
jerosejr is offline
Old 04-25-2005, 09:15 PM
outlawinil's Avatar
Use Meguire's Wax ball and wax.
outlawinil is offline
Old 04-25-2005, 11:35 PM
VIPER7's Avatar
If all else fails sulfuric or hydrofloric acid will take it off. Sulfuric would probably be the easiest to get at a building supply store.
VIPER7 is offline
Old 04-26-2005, 08:23 PM
thanks guys ....
Chris288
7
09-20-2007 04:31 PM
msel9669
09-20-2007 08:53 AM
Fenderjack
14
02-14-2007 07:22 PM
pb
7
08-24-2005 01:19 AM
Pure Energy
02-21-2003 07:05 AM
Quick Reply: Rust on Gel Coat .......
