Drilling holes
What's the best way to drill gel so you don't chip it?
Hole saws and regular drills. |
Re: Drilling holes
Number of different ways to go about it.....first make sure to tape the area you want to drill through with masking tape. The blue painters tape works best for me because it peels off nice.
If you gonna use a hole saw then start the saw in REVERSE and let the teeth of the hole saw saw their way through the gel first. This works cause the sharp edge of the hole saw is not catching the gel its just scuffing its way through. When you get through the gel the run the drill the proper way to cut the hole. Another way but slightly more expensive is to use a hole saw made for tile cuting. they have the diamond encrusted type and they will melt right through gel realy nicely :) |
Re: Drilling holes
Thanks Wally.
Re: Drilling holes
After your done drilling use a countersink on the hole. That will keep spider cracks to a bare minimum. Brian
Re: Drilling holes
Re: Drilling holes
Originally Posted by hillbilly24
This is also a good idea but again make sure to run the countersink in reverse to prevent cracking. better yet but more time consuming is to use sand paper to make the radiuses.
Re: Drilling holes
never tried the stone bit, sounds like it would work though, as far as putting the dust back in just call JCperf and ask to borrow his duct tape, it goes right back that way, it even comes in lots of cool colors these days :D If you do use the countersink method make sure you get a countersink with atleat 3 cutter edges, preferbaly 4 the ones with onyl two tend to jump and grab gel even in reverse.
