Filling Holes Iin Transom!!
I need to fill six holes from improperly mounted trim tabs, am i correct to use wooden dowels dipped in fiberglass resin?
should they be tight for the holes or just slide in? should i fiberglass them inside and out to prevent separation? and is this strong enough for the transom? |
any one?
Hi Joe, yes they should be plugged with a wood dowel if its any bigger than about 3/8ths of an inch. The process is just like the thread on filling dash holes.
http://www.offshoreonly.com/forums/s...d.php?t=185096 I usually leave just a bit if room for the dowel and bond it in with westsystems 404 than cap the ends with 2 layers 1808. |
thanks alot!!
what's the best way to fill screw holes that don't go thru the transom? Fill em with 4200?
Just took off a transducer, need to plug the tiny screw holes. Thanks. |
Glass dave, I just patch a couple trim tab holes myself. I was talking to Spectrum Color and the owner instructed me that if I did it that way the dowels would eventually soak-up / absorb moisture and pop out and blow through the gel. I used plenty of resin and sealed the exposed end up as well before applying gel. I think I am good and I dont see any problems.
Do you think this guy is going a little on the extreme side? You are totaly my gel-coat hero and have never gave me bad advice, except you make it seem so easy! Your the BEST...thanks! |
Why would using the dowel plugs be any different than the wood itself of the transom? I don't see the issue.
Originally Posted by US1 Fountain
(Post 3118351)
I would think if the plugs are able to soak anything in after the fact you have other problems. Looks great Brian! |
Thanks dave. What do you reccommend for a high density filler?
I will go ahead and wet sand it out and put a little finish on it. |
