Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Removing a fresh gelcoat repair >
Old 05-14-2010 | 10:42 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Removing a fresh gelcoat repair
Had a 12" scratch repaired a couple weeks ago that was in the gel only. The new gel does not match as well as I'd like, plus the repair is a larger area now. Can I sand the fresh gel down/off to the original gel, basically to the point of where the repair looks more like the scratch was filled in flush as that would look less noticable than the larger off color repair? Not sure if the new gel eats into the old gel.
US1 Fountain is offline
Old 05-14-2010 | 07:03 PM
Yes!
Wet sand it off and you will end up back at the original gel. The new gel is sitting on the original gel, just make it go away and you will end up with a very small discolored area, the scratch, that looks different. Use a sanding block so it dosen't get all wavey on you.
RaggedEdge is offline
Old 05-16-2010 | 10:48 AM
did you shoot your gel or did you use the gel putty? I have been experimenting with both lately trying to get it perfect.
How did your transom turn out?
Brian
baja_brian is offline
Old 05-16-2010 | 06:00 PM
fRANK , god man you do not need to wet sand the jel off that has just been sprayed . Frank give me a call R T and i think you still have my number ? frank , better yet i will shoot you an E mail from a different site .
SUE C Q is offline
Old 05-16-2010 | 06:26 PM
Ginger or Mary Ann?
It was sprayed.
I ended up paying a guy come and shoot the transom and the scratch. I wasn't comfortable to do the transom myself.
Old 05-20-2010 | 10:42 AM
Originally Posted by RaggedEdge
Yes!
What grit do you use to color sand?
BRET is offline
