How to paint outdrive?
Registered User
My buddy used Epoxy spray paint for appliances... great job for $7. lol
For being SUPER Budget,why not?
Sorry about the crappy pic, I snatched it off his facebook.
outdrive paint.
Sandblasting is def. ideal. If you use the Zinc-Chromate base, take the proper precautions when it comes to using a breathing apparatus. The stuff is great for creating a protective barrier for your drives, but it will also melt your lungs down. Here is some pics of my last drive project.
The paint is Imron 5000s.
[QUOTE=KEVLARKAT32;3164701]I sandblast then use BLACK epoxy primer then single stage black urethane . It looks wet and slick[/QUOT Thats what i do! but im a bodyman and i have the materials already! put some new decals on looks brand new! Good luck!
Jason
Jason
I have my outdrive off and I wanted to paint it since it needs it bad. I wanted to know what people use including techniques and also what kind of success they've had with them. I was doing a little reasearch online and read to sand the outdrive with aluminum oxide sand paper. Is this different than using just normal 120 grit sandpaper to prep? Also what does everyone use an orbital sander? Basically a step by step of what material to use to sand and paint with would be great.
