chris cat fuel tank replacement
anyone have any experience with refoaming tanks on a chriscat, I have one that is loose but they aren't leaking, any advice would be greatly appreciated. thanks
JBBEARD
No Big Deal
I just did mine and used cans of "good stuff" from hardware store. Sprayed it in , let it expand, re fiberglassed the areas we removed to get it in, Looks good as new!
thanks for the info guys, jbbeard, did you remove sections of the cockpit floor, if so how did you go about rebounding it back in?
I am thimking of cutting out the section of floor above the tank, repairing the foam and reinstalling the tank, cut back the top layer of flooring and the core leaving the bottom layer of the liner intact and start bonding from there. I was thinking of using 1708 for the glass, unsure what coring material was used, maybe balsa?
JBBEARD
JBBEARD
Proper Foam: http://www.uscomposites.com/foam.html
I would not do that- I just drilled a few holes big enough for the foam tube and removed a little of the bulkhead in the engine compartment to allow foer insertion of foam under and arround the tank. If you pull up the floor- you might as well take the boat apart and I worry about structural integerity- Less is more!
JBBEARD
