Best way to seal through hull bolt holes on transom
Pokher Ace
From what i was advised on another site from an MTI and other high performance Boats glass specialist is the Marine-Tex is good as is or use a epoxy with either a West Systems 404 or cab-o sil product for lightweight structural filler mostly for vertical applications.
Hope this helps you as well. Where the Hell is Hammer City?
Aaron
Aaron
Racer
Racer
When I have repaired old thru bolt holes that I am reusing, I over size drill and paint some epoxy with filler in the large holes. Then insert the correct size PVC pipe. When it is dry I have a sealed bolt hole.
