Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Best hull cleaner I've used >
Old 09-12-2010, 06:36 PM
GO4BROKE's Avatar
Default Best hull cleaner I've used
I usually use FSR to clean the coffee stain. Normal soap for dirt. I used Power1 by fountian of youth restoration products. It cleaned the coffee stain as well as FSR does, with less work to apply. It also cleaned off some marks that have been on the hull since before I owned it. Its also a great rust remover. I had some rust stains on the cockpit floor it took off, and the brass drain plug on the transom is now brass instead of black. The boat bottem looks better than it ever has. I don't sell this stuff, just sharing something that works great. I am ordering all their other products to see if they are as good. They say their vinyl cleaner is waterproof and a uv protectant.
[img][/img]
GO4BROKE is offline
Old 09-12-2010, 07:04 PM
GO4BROKE's Avatar
http://www.fountainofyouthrestore.com/power1.html
forgot the link
[img][/img]
GO4BROKE is offline
Old 09-13-2010, 09:53 AM
Neno the mind boggler
glassdave's Avatar
we tried it side by side with everything they had at one of the marinas i was doing some work at last week. Nothing even came close and this place was up river and also a rack/launch so i had plenty of test boats from our grungy river. This stuff is friggin great! It was also the least harsh (acid burn/smell)
http://www.offshoreonly.com/forums/g...ll-stains.html
08 OPA High Points Champion
glassdave is offline
Old 09-13-2010, 09:58 AM
Same here, great stuff!
smdude is offline
Old 09-13-2010, 03:24 PM
Great results also. I spray it on everything on the transom and it cleans and shines everything. I haven't used any of the other products yet though.
jdub is offline
Old 09-13-2010, 04:02 PM
Received 4,326 Likes on 1,241 Posts
Thumbs up
thnax for the heads up I`ve been looking for something better
ICDEDPPL is offline
Old 09-22-2010, 07:16 PM
Feel free to call me at 315-796-2598 and i'll get some out to ya! Thanks for all the positive responses guys.Anyone else who has tried this stuff,I'd love to here your responses.
heater63 is offline
Old 09-23-2010, 09:40 AM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Do you have to apply wax when you are done? I used acid in the past, and the brown line would come back faster even after wax.
1BIGJIM is offline
Old 09-25-2010, 09:03 AM
It would be a good idea to rewax after use depending on what your using for wax.Certainly never hurts to apply another coat of wax.
heater63 is offline
Old 09-26-2010, 08:54 PM
GO4BROKE's Avatar
Cleaned the toilet in the head pretty good too.
[img][/img]
GO4BROKE is offline
