?? for Glassdave
I'm interested in the Vibra cut. I looked for instructions on the application and or video but I'm still not sure about what I need. From what I read it's a two step process. Correct. Vibra then Totally buff. One more question is wool the best way to apply and do you change the pad when you remove the Vibra cut?
yes, for gel wool is best. I always change to a fresh pad for Totally Buff, Using Vibra you will need to spur the pad ocasionally but Totally seems to be fairly self cleaning. I only use Vibra on very heavy oxidation.
08 OPA High Points Champion
Thanks Dave! Totally Buff come in a gallon b/c we have two boats 27 formula and a big 24 Chris Craft?
Hey Dave..... I thought you said you work with "glass windshields"..... not fiberglass?????? You do know your stuff though! Keep up the good work (on both types of glass!)
You'll love Totally Buff, biggest hook for me was how easy the clean up is. A lot of compounds leave a pretty good mess but this stuff works as a diminishing compound, it sort of breaks down as you work it and cleans its self from the pad as well.
