The Re-Birth of an Apache Scout
#181
After the Superbowl, I conned a friend to help set in the cockpit part I cut out to get to the stringers. Seeing this in place was a great achievement. It really felt like I rounded the corner. Unfortunately, we were still getting a lot of snow. I had to give up a day to dig out the driveway...
#183
The first image shows how the results of the mold sagging when filling in the outboard cut out... I wasn't happy about that but kind of was regrouping on the next steps to take..
#185
Jr,
Those burred out stress cracks look pretty deep. Would you not need a little glass fiber in there or do just fill it all in with epoxy filler?...........I know epoxy (west system) doesn't come cheap........check out www.aeromarineproducts.com I here good things about it. I've been using systems three @ $127 for the 1-1/2 gal. set...............Aero is $85........what havee you been paying?
#186
Once the cockpit was fitted to be re glassed in, I had to make sure the removable floor would fit back in. With much amazement, it was good to go.. The next step was to glass it in. I believe I glassed in 3 layers in on the bottom, then filler, and then 3 layers of glass on top. It was pretty straightforward.
#187
Jr,
http://www.uscomposites.com/epoxy.html
