OK to notch stringers for clearance?
I have an 88 Baja 235 Force, and while the engine is out, I was thinking about extending the notch in the rear stringers a few inches further forward to give me a little bit more room to get to the starter if necessary and the oil filter (using a t-stat sandwich oil cooler adapter). There are already two notches back there that extend all the way to the stringer forward about 8 inches or so - the notches are about two inches deep off the tops. I can't see how extending them forward a little bit could upset the structural integrity of the motor mounts, but I thought I would run that across some of the fiberglass experts. Of course, I will go back and encapsulate the cut area with fiberglass cloth and resin and bilge paint.
I'll post a picture if necessary. I'll be in there working on it this weekend. Thanks.
My real concern is less on the starter side (already have the mini Merc starter) and more on the port side for oil filter clearance. I added a thermostatic sandwich oil filter / cooler adapter, and the filter mounds directly to it. Makes changing filter a bit of a pain, but eliminates about 5 feet of restrictive oil cooler lines and fittings. The goal is better oil flow to the engine, and the ability to keep the oil up to proper temp.
