removing resin drops.....im a slob!
Did a cpl repairs on a boat & now I'm noticing some resin thats on the non skid platform. It's ground in pretty good & dirty.
Any magic tricks to getting these off? |
Take a little sharp chisel and tap out, most of the time they will pop right up without damaging anything
It's not raised anymore, but rather ground in with dirt / $hit mixed in
Ur screwed.
Lol
I've tried steam powerwash. Tuff stuff, bleach, raping it with the side edge of the buffer. I know someone has some secret potion!!! ? |
fixx
super X non chlornated brake cleaner and a fine scrub brush,,get it on quick scrub quick and wipe it off quick..it works! acitone will also work but is a little stronger..
Acetone was a no go....
Gasoline maybe. It looks like a dozen bird shats on the platform! Nfg |
It's not going to come up, unless u chip it.... At least I have found nothing that works
Scrape it with a razor blade. Keep it at a 90° angle or you will **** it up. Then hit it with 2000# and rub it. Megires stones work well too...
