Straighten out style lines?
I want to restore this old 30 Corsa, but the style lines are crooked.
It looks like it came from the mold that way, the boat is otherwise straight and solid. Does anyone know if this is worth attempting? |
If you can see just from looking that the boat isn't fair its probably pretty bad. 1st thing I would do is stick a baton (a long perfectly straight stick ) on the hull that will show you all the high and low spots along the hull. Its ALOT of work but the great thing about fiberglass is you can fix or change anything
