86' Wellcraft Scarab Panther Transom replacement?
#31
hello, I know post is older
but I just went thru this, cut out transom and main stringer
had it all replaced
as others stated it a job.
I posted a lot of photos
good luck!!!!!!!!
do it once, do it right
had it all replaced
good luck!!!!!!!!
I am about to start a transom replacement on an 86' Wellcraft Scarab Panther; any special circumstances or issues I need to be aware of before I start?
[ATTACH=CONFIG]554736[/ATTACH][ATTACH=CONFIG]554737[/ATTACH][ATTACH=CONFIG]554738[/ATTACH][ATTACH=CONFIG]554739[/ATTACH][ATTACH=CONFIG]554740[/ATTACH][ATTACH=CONFIG]554741[/ATTACH][ATTACH=CONFIG]554742[/ATTACH][ATTACH=CONFIG]554743[/ATTACH][ATTACH=CONFIG]554744[/ATTACH][ATTACH=CONFIG]554745[/ATTACH]
#32
I took a circular saw , set the depth to maybe 1 or 1.25,,cut a cross hatch pattern in transom. made it easier for removing rotted wood.
flash ...out
flash ...out
#33
Remember this restoration process if you plan to keep your Scarab for another 10+ years. Why?......because you will likely get opportunity to redo the transom and stringers again.
#35
My floor is lowered on the Port and Stb side and it is slightly lower in the middle over the gas tank. It is a 1 pc unit that is trimmed in SS. Let looks pretty good and really helps you hunker down when running hard.
#36
WOW, 30 FT SCARAB WITH ALPHA'S????
I HAD 86 26 NOVA SPYDER W TW 330HPS RARE,,WITH ALPHAS..
JUST FYI, I JUST WENT THRU COMPLETE REBUILD ON MY 38 scarab TRANSOM ROTTED...MAIN STRINGER ROTTED TOP TO BOTTOM...
good luck
good luck
