Vacuum Bagging down Balsa Core to Hull
Got about 20 sheets of balsa core to bond to a hull . Anybody ever bag it down? Thought maybe it would eliminate the inevitable voids under the coring .
Also thought about Infusion , if it would work all in one shot ? CSM on hull , Balsa on the CSM , layer of 1708 on top , use vinylester. How about bagging the core into the Corebond , saving the bag , then using it for the reinforcement of corebond cures. |
Look on youtube might find some info there.
Originally Posted by dunnitagain
(Post 4492421)
had to post - the hull birthed and proud of it. Scroll down and read all - some great info as well.
http://www.laveycraft.com/construction-of-29-nuera |
Hey Dave , this is a repair , Ive got 2 Fives of B-70 and the trowels ready to go . But I'm lazy , and thought about just infusing the whole thing .
Have you ever done it that way before ? Isn't that the way Skater does it ? I think it would be a clean way to do it , and not be a frenzied PITA that it always is . Plus the core and reinforcement would be void less compared to the hand layed. Correct me if Im wrong. |
Thats a bad azz locking boat there BUP.
(Post 4492673)
Have you ever done it that way before ? Isn't that the way Skater does it ? I think it would be a clean way to do it , and not be a frenzied PITA that it always is . Plus the core and reinforcement would be void less compared to the hand layed. Correct me if Im wrong. Yes Skater bags and infuses but their lamination crew is the best in the biz, the level of fit and finish of core sections is amazing. Setting the core using B70 is a very clean and simple process and using the BPO catylist gives you a pretty long work time on the order of a half hour to forty five minutes. Make sure to prime both surfaces and give proper flash time before setting. Simple and clean like setting floor tile, do one section at a time and mix core bond as you go instead of all at once. For big jobs i have a guy mixing B70 as i am setting one section at a time. :D |
Thanks Dave , That sounds like the course to take .
