Transom replacement on Checkmate 281
#113
I´ve following your work - great! I´ve bought a 1989 Maxxum 281 a few months ago (Twin-version) and have the same work to do. It´s al long way - but much fun.
I did it two times before with 20ft-boats and every time, i want to give up or tired of working, i´ve looked the pictures from the beginning - what a great and big work is done!
So - hope, you will be back in the boat. Can´t wait for the next pictures! :-)
#114
Sprayed two coats of gel with the dump and coated with PVA. Ruffer than a cob but hopefully enough material to block smooth.
Made a 26\" foot for the air file just to knock the worst off. Start blocking by hand after that. So far the worst part is trying not to notch the edges where the strakes meet the bottom.... Air file digs qick. Hand blocking is where it's at.
Sharpened the strakes and filled anything over a 1/16 with glass. Used vinylester putty for the thin stuff.
#115
You might want to consider sharpening at the transom too. A friend of mine used to have a 25' Checkmate outboard (very similar hull) many years ago and doing that cured his porpoise issues.
#118
I've been following this project from the start and look forward to each new update. Thanks for the detailed posts and pictures. You do very nice work!!!
When you are finished can I drop off my 251? ... lol
#119
Good idea, someone beat me too it though it was sharp when i started.
