Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Painting plexiglass, how to do it????? >
Old 05-06-2017, 09:32 PM
aquaforce's Avatar
Default Painting plexiglass, how to do it?????
It was no easy task but I got my cabin door out so I can paint it. That old plexiglass is way to easy to see through so I plan to paint it white to change color and add privacy.
Does plexiglass have to be specially prepped to adhere to the paint right? Is acid etching needed to make it bond to paint?
What can you tell me about this paint project?
TIA
aquaforce is offline
Old 05-07-2017, 05:19 AM
2jz
Vynil wrap them hundreds of colors and designs to choose from. I think trying to paint them would take up alot of time to prep,paint and correct paint that would flex some with plexiglass.
Other option is buy plexiglass in color that fits your needs. You can order it cut to size
2jz is offline
Old 05-07-2017, 06:09 AM
I would think a vinyl spray for upholstery would be flexible enough. and you could experiment on a 10 buck piece of plexi from home depot-lowes...maybe spray the inside of the door so outside still has same texture-look as before.
dereknkathy is offline
Old 05-07-2017, 06:30 AM
I painted one of those clear hood deflector years ago. Painted the back side as already suggested. Just used some cheap Krylon spray bomb. Looked great and lasted a long time. Don't remember doing any special prep other than wiping down with a tack cloth.
sonicss42 is offline
Old 05-07-2017, 12:52 PM
aquaforce's Avatar
I like the endless options with wrapping but less than permanent is what makes me consider something that will stay the way I make it without the need to be done again sometime.
Old 05-07-2017, 01:09 PM
aquaforce's Avatar
The Formula cabin door plexiglass is very thick, 1/2" and curved into an "L" shape. The clearance to get it out is very tight and other obstructions had to be removed that were in the way so I don't want to do this again.
My concerns with paint are around the expansion and contraction of this plastic material's thermal properties and keeping paint on it. If it is bonded right all should work well but I am not sure of what is required for a good adhesion. If this gets overly pricey then it would compare against just buying a new white Plexiglas door from Formula. I'm sure that is a high price.
Old 05-07-2017, 03:01 PM
Try calling TAP Plastics out in Calif. Plastics/Acrylics/Fiberglass is all they have done for 30 years.
GLENAMY 242SS is offline
Old 05-07-2017, 04:03 PM
2jz
TAP plastic a great choice i have used alot for starboard and acrylics projects. Buying 1/2 acrylic or plexiglass can get to be expensive and on top of that it needs to be curved. I still think vynil wrap is best. You don't have to do both sides of the door just exterior side and trim to fit. Should last very long time.
2jz is offline
Old 05-13-2017, 02:38 PM
aquaforce's Avatar
Formula said: 1) Wipe with plastic prep.
2) Scratch with 800 grit
3) Wipe with plastic prep
4) Spray with adhesion promoter - let flash off
5) Spray with value shade
So now I need to find a local painter to do this for me.
Old 05-13-2017, 02:40 PM
SB
Received 3,116 Likes on 1,403 Posts
Is value shade acrylic ?
SB is offline
