Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Epoxy primer on top of anodized cast aluminum...OK? > Epoxy primer on top of anodized cast aluminum...OK?
Like Tree2Likes
Old 08-12-2017, 04:35 AM
Originally Posted by northernoffshore View Post
coal tar epoxy it
Is there any prep work that has to be done before applying it?
SSkz is offline
Old 08-16-2017, 11:55 AM
My Boat: 1989 24' Bass Buggy Pontoon ls1
I painted the toons on my pontoon with Epoxy primary then paint. I sanded them with 120 on a DA wipe them down with acetone, sprayed the EP let dry, scuff with red scotch brite then painted. Its tough as nails and has been holding up awesome.
I did use this stuff on the bottom of the toon and you cant scrap it off with a knife if you wanted too. It spendy and a PITA to install but seemed to be worth it.
GatorGlide.com - slick bottom coatings, Easiest on the market to apply, by far the slickest!
turbom700 is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
OSO Advertiser
