Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Transom replacement 1995 Webbcraft 252  Help Glass Dave >
Like Tree20Likes
Old 01-08-2018, 09:09 AM
  #51
My Boat: 1995 WEBBCRAFT 252 ENTERPRIZE
My side floor's and walls were carpet on my boat, I had to take all of this off to do this. The glue and residue were horrible to remove, but finally got it all off and cleaned and sanded. for paint.
Attached Thumbnails Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-1.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-2.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-3.jpg
Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-4.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-5.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-carpet-6.jpg
glassdave likes this.
kip4234 is offline
Old 01-29-2018, 07:59 AM
  #52
Finally starting the process of putting the boat back together, I still have along way to go but got a few things put on this weekend.
Attached Thumbnails Transom replacement 1995 Webbcraft 252  Help Glass Dave-b1.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-b2.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-b3.jpg
Transom replacement 1995 Webbcraft 252  Help Glass Dave-b4.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-b5.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-b6.jpg
glassdave and hblair like this.
kip4234 is offline
Old 02-05-2018, 03:19 PM
  #53
Made some more progress this weekend working on exhaust tips and trim tabs. I used the big rubber gaskets for my exhaust tips for seals on tips and used epoxy on all the screws. Under water lights and trim tabs I used 4200 3m white on lights and black on tabs. Put 3m blue tape about a 1/8" from all of these items and when I pulled the screws tight finished the bead around the outsides of these and then pulled the tape off.
Attached Thumbnails Transom replacement 1995 Webbcraft 252  Help Glass Dave-w1.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-w3.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-w2.jpg
Transom replacement 1995 Webbcraft 252  Help Glass Dave-w4.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-w5.jpg   Transom replacement 1995 Webbcraft 252  Help Glass Dave-w6.jpg
kip4234 is offline
Old 02-05-2018, 03:20 PM
  #54
putting new exhaust flappers on the tips also.
kip4234 is offline
Old 02-13-2018, 06:45 PM
  #55
My Boat: 1987 Scarab Panther
Take your boat to glassdave as he is the pro for fiberglass & transom work. Last I heard, he was now taking new orders with a 45 day guaranteed turn around time including a 20% winter discount 😎😜. Please just send him an email.
Ben
BenPerfected is offline
Old 02-14-2018, 09:42 AM
  #56
Neno the mind boggler
glassdave's Avatar
My Boat: Batboat, 38 Scarab Thunder, 16 Sidewinder, 27 Magnum
Originally Posted by BenPerfected View Post
Take your boat to glassdave as he is the pro for fiberglass & transom work. Last I heard, he was now taking new orders with a 45 day guaranteed turn around time including a 20% winter discount ����. Please just send him an email.
Ben
and free pick up and delivery within the continental US . . . oh hell . . . Alaska and Hawaii to . . . and Canada . . . lol . . . (disclaimer . . . . friends, family, or anyone reading this or any boat owners trying to take up on this offer not eligible)
endeavour32 likes this.
08 OPA High Points Champion
glassdave is offline
Old 02-14-2018, 11:21 AM
  #57
hblair's Avatar
My Boat: '79 Scarab 300 '81 Scarab 377 Flat Deck
Good looking work. You should be done in time for warm weather.
hblair is offline
Old 02-15-2018, 09:24 AM
  #58
Thank you, I am trying to do the best job I can, I would have never tried this in a million years if not for Offshore only reading every transom repair ever in the search fields and if not for Glass Dave what a blessing it is to have someone that will walk you through the process and post for all of us to learn and do from his many hours of trying and learning through the years. I am hoping to be done with this by Apr 30 and have a water test. I have a lot of wiring that needs sorted out and redone while I am here. need to plumb tabs and new wiring and gauges for them. install new depth finder puck actually going to install two, one for a backup since they epoxy to the floor under engine. going to redo bilge pump and add a second to only work on switch non automatic on the second one. rewire and reset engine. Daughter is getting Married in March and my wife has me doing millions of honey do's for this also so I am very limited to time on this from work and wedding.
Attached Thumbnails Transom replacement 1995 Webbcraft 252  Help Glass Dave-getting-closer.jpg
kip4234 is offline
Old 02-15-2018, 02:55 PM
  #59
My Boat: Cruisers 500 express
What is that inspection hatch for. Never seen one that close to the water before..
Chris
Blueabyss is offline
Old 02-15-2018, 03:29 PM
  #60
I guess when the built my boat they did that for the other side of the fold down ladder hardware nuts that went into the swim platform area and not to the outside.
kip4234 is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
OSO Advertiser
