Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Pearl white on a topgun? >
Old 12-08-2018, 09:22 AM
  #31
Originally Posted by Baja Rooster
I plan on painting some pearl white on a moto soon and have never done pearl before. Are you saying to fog over it in dry coats to get the pearl effect?
Yes , dry/ light medium wet . You will start to see effect after 3rd or so coat. You are building up a very fine powder.
open87 is offline
Old 12-14-2018, 11:34 AM
  #32
White pearl is like one of the easiest colors to shoot on a boat. Youll also find that most of us painters are shooting a base color then icing a pearl over the top. Or mixing a candy pearl off our bank. I just finished a 38 topgun that is all white pearl. ill see if i can post the pic
315duramax is offline
Old 12-30-2018, 09:03 AM
  #33
Infinit QAB
open87 is offline
Old 12-30-2018, 09:07 AM
  #34
You can see on spray out card that 4 passes of pearl will build the effect
on this particular color 12 passes give the correct look .
Some colors require more passes.
open87 is offline
