Removing glue from fiberglass
Unfortunately, my boat is getting older. The foamed backed vinyl that is on the ceiling is starting to fall down. So I am cutting the rest of it out and got most of the foam out. Question is, how do I remove the glue from the fiberglass? Thanks
https://cimg8.ibsrv.net/gimg/www.off...f24f68c00.jpeg https://cimg9.ibsrv.net/gimg/www.off...8a9a3de8c.jpeg https://cimg0.ibsrv.net/gimg/www.off...4709d5df0.jpeg |
Not much you can do besides scrape and sand it
You could try one of those paint stripper wheels that go in a drill. Sorta like a wire wheel but made with flexible plastic elements. Try HD or Lowe’s. Whatever you do it will be messy. Be sure to wear a respirator. |
Is there an adhesive remover he could spray on there that will not hurt the fiberglass beneath it? |
Thanks for the suggestions everyone. I'm thinking, lay down a tarp to trap all the dust while I use the paint stripping wheel. Very light pressure to ensure I don't mess up the fiber glass. I guess a chemical is not recommended as it may mess up the resin/fiberglass? Matt |
i am going through this right now on my stinger..... pain in the you know what!! I went the wire wheel way on my cordless drill...but i went with a metal wire wheel as i didnt feel he plastic one i was using was getting through it fast enough.....your arms hurt after a while of laying on your back and pressing on the ceiling :) just have to power through it. and it hasnt hurt the fiberglass at all as far i can see anywhere.
Buy a flat blade for your sawzall. They are like a putty knife and will get most of the residue off. You don't need to get down into the glass fibers if you are going to recover the laminate
Use a plunge cutter. HD or Lowes sells them. Fein tool originally designed them,now everyone makes one. I would try a curved smooth cutter. Very controllable, most tools have variable speed. Lots of different cutters available.
I had glue residue in my cabin from some carpet that was glued in. I tried all sorts of solvents, but finally had great luck with mastic remover. wiped right off. good luck.
