Stopping delaminating?
Old 04-03-2019 | 06:33 AM
Default Stopping delaminating?
Cutting a new anchor locker, I can see a large amount of the upper Fiberglas from the plywood. What would be the best way to get an adhesive in the area and what would be the best adhesive to hold?
gttdnbman is offline
Old 04-04-2019 | 09:31 AM
resurrected's Avatar
I don't know if there is an easy way to fix that, if it not just local to the area you have cut.
Drill holes through the glass and inject epoxy with a syringe into the space and draw up with screws, then remove the screws and repair the holes and deck.
I would also prop it up from below.
I don't even know if this is a permanent solution
Someone smarter than me should chime in
resurrected is offline
Old 04-04-2019 | 10:32 AM
You might be able to inject thickened epoxy from the crack opening with large syringes available from Amazon with an extension tip added to get deeper into the crack. Try to determine how deep the delamination is. Start clamping at the gap shown in your picture with plywood on top an bottom to spread the pressure so that the epoxy gets forced into the crack deeper. You may still need to screw the laminate together. The syringes are made for refilling ink cartridges I believe. They are super handy.
ren3 is offline
Old 04-06-2019 | 07:43 AM
scarabman's Avatar
Not so sure you are actually seeing delam there? Is it possible you are just looking at an air gap between the deck and the hull/liner as it may have been built? Is there wood fiber/veneer stuck to the underside of the underside of the deck glass?
scarabman is offline
Old 04-06-2019 | 09:19 PM
Tinkerer's Avatar
^^^^^ I was thinking the same thing. does the fiberglass or plywood look torn up with strings of the other material stuck to the other?
Tinkerer is offline
Old 04-09-2019 | 07:21 AM
Doesnt look like Delam to me either.
dunnitagain is offline
Old 04-09-2019 | 08:46 AM
At least its dry!
Keith Atlanta is offline
